QED Micro or Silver Micro
scene
789
187
19,070
Trying to finally sort out my surround speakers in my new house. Due to the size and geometry of my room, I need to get 30m of cable [:O] I'm using QED Silver Anniversary for the front three and was thinking that for the rear pair, this was:
[*]Overkill [*]Too big to run discreetly [*]Expensive
So I thought I'd go for the Silver Micro, as that would be a good match for the front.
Is it worth it? Should I just go for cheap'n'cheerful QED micro, and save myself £60? Or should I look at different cables altogether?
I'm thinking of getting some Q-AV BMR satellite speakers as surround speakers, but there is a possibility (Mrs. Scene allowing [😉] ) of upgrading to RS-FX or RX-FX down the line...
I have the same cable as you for my Centre and Fronts and had the same dilema
I use this for the 4 rears i have, Qed One Incognito 20m reel
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/6306
Yeah you could spends hundreds on other cable, but this does the job fine for £11.95 each reel!!!!
Trust me it works a treat
, for those prices you cannot go wrong. Plus its super thin and flat
Garth Man:
Thanks for the heads up on that Garth Man
This is the one that you can't find on the QED website directly, only via google!
yep I had the same problem, so I rang QED up and they assured me that its still an active QED product, just isnt avertised on their website
Strange I know, trust me though nothing wrong with the cable works a treat
I trust you! Just amazed how difficult it is to find this gem!
Just dithering over banana plugs at the moment, then I'm going to order 2x20m!
Garth Man:
wow even my own Girlfriend and daughter dont trust me (when it comes to money that is....) haha appreciate that
lol
Depends if you need teh QED Airlocs (which i have) but i also use these ones, pack of 20
http://www.thatcable.com/acatalog/info_banana_plugs.html
They are a bit shorter, but do the job fine
Yes, I'm debating whether to get Superfi to terminate them at 15m lengths with the Airlocs. Only issue is, I'm not sure if it will be harder to run the cables with the plugs in place... Might accept the slight loss of perfection *sigh* and go for some home-fitted plugs
Well the 4 rears are connected with the That cable plugs and they work fine, you just need trim off the ends to expose the cable strands, then solder the ends and screw on the plugs dude
it was quite easy actually, I was rather surprised, not really normally good at things like that (must be getting old....)
Scene,
Unless they are properly soldered, you are bound to hear the occassional 'click' - I did.
I just use them bare - no issues.
Ronald
At what price/quality level with rear speakers is it worth upgrading from something like QED Micro which is what I've been using for the last few years?
Garth Man:
Thanks Garth Man
I've just ordered two 20m reels of the Incognito from Superfi, to hook up to the pair of Q-AV rears I've also just ordered. (Unfortunately not from Superfi, as they're out of stock.) Bargain price, and I'm going to end up with 2x5m left over.
Maybe I'll save them for when I get a new amp so I can try out front height speakers...
