As home cinema set I have the Jamo A 101 HCS 5 and Marantz NR1403 receiver. The combination is fine for movies but I would like to have a better sound for playing music. I want to replace the front speakers including the center speaker. I have heard the Acoustics 2020i and to me they sound great. I have two options in my mind:
Option 1: Replace front speakers with 2020i and center with 2000Ci. I keep the rear speakers and the A 101 sub for bass support.
Option 2: Replace front speakers with concept 20 and center with 2000Ci. I keep the rear speakers and the A 101 sub for bass support.
The left and right front speakers will be mounted on the wall with B-Tech BT-77 side clamping loudspeaker wall mounts. The living room is 10x5.5 meters (with open kitchen). Distance between left and right speaker is 4 meter. Distance front and back speakers are more or less 5 meters.
Which option is best? My main concern is the difference of specs between the center speaker and the concept 20s.
