ps3 home cin
I am thinking of buying a samsung htc 5500 home cinema system it has 1 optical input which i will use sky hd for and 2hdmi if i use one of those to connect my ps3 which settings in the ps3 menu do i use to ensure i am getting the best audio from it.any advice would be appreciated.
If you have the older "fat" PS3, set Audio Output Settings under Sound Settings to be HDMI and ensure all the relevant Linear PCM settings are ticked for 5.1. Then, under Video Settings, set the BD / DVD Audio Output Format (HDMI) to be Linear PCM. Your PS3 will then decode the HD audio soundtracks to PCM and you'll be getting the best audio.
If you have the newer PS3 slim, follow through the Audio Output Settings wizard in the same way i.e. selecting HDMI, but under the Video Settings, set the BD / DVD Audio Output Format (HDMI) to be Bitstream. Since the new slim version can bitstream these formats, your Samsung will then decode the HD audio formats and you'll be getting the best audio.
