PS3 Blu-Ray remote - is it Bluetooth?
Yes it is and no it can't. You need to add something like this, which plugs into a USB port on the PS3 and gives infrared remote control, which the Harmony 555 can then operate.
I've got this and it works well with my harmony but it can't do the power. Rob
http://www.gameseek.co.uk/pd/PS36jkkhuqja5e/
hifi_nut:I've got this and it works well with my harmony but it can't do the power. Rob
Please help!
Bought a Logic3, but can't get it to 'talk' to my Harmony 555.
Tried using the Logic3 entry in Harmony's database & it does not work.
Tried manually loading the commands but Harmony's onscreen prompts don't correspond to Logic3's buttons. Er...?
