Portable Headphones for Jazz
My V35 ThinQ ( same Quad DAC and amp ) will drive every headphone I own with ease. So you're only limited by budget.
The Sennheiser HD650 or Massdrop x Sennheiser HD6XX which is the same headphone with a different finish are excellent choices for jazz. The 6XX is cheaper but may not be available depending on where you are. What's your budget and where would you be buying from?
