Portable digital player with digital out.
Al ears
This may be a daft question but does anyone know of a portable hires player that has digital out via a micro USB port like my mobile phone has?
Just occurred to me that may get better SQ by bypassing its DAC and using my USB dac / headphone amp with it just like I do with my phone occasionally.
Fiio X3 2nd gen and X5 have 3.5 mm output which could be used as analog and digital output (spdif coaxial).
I have the original X3, was looking for something that has digital out through micro USB although I get the feeling this is only done on mobile phones.
http://www.hifiheadphones.co.uk/hidizs-ap100-portable-lossless-digital-audio-player.html
I heard the Fiio X5 but this is much better and it is cheaper than the X5. It is superb as I own it.
I would wait for this to come out if I were you.
http://www.hifiheadphones.co.uk/lotoo-paw-5000-portable-lossless-digital-audio-player.html
regards
Rich
rich51080 said:
http://www.hifiheadphones.co.uk/hidizs-ap100-portable-lossless-digital-a...
http://www.hifiheadphones.co.uk/lotoo-paw-5000-portable-lossless-digital...
regards
Rich
Thanks, I will look into those. The X3 does have a 3.5mm digital out socket, do I need a special cable to connect to digital in socket on the USB Dac / headphone amp?
rich51080 said:
You can buy a connector to plug on the end. Costs a couple of quid.
To be perfectly honest if the manufacturer chooses to fit such a non standard fitting I would expect then to include an adapter. It's still scratched, if I wanted 2.5mm balanced headphone jack I would have bought an Astell & Kern. 🙂
Good point. I just do not get why manufactuers are using the 2.5mm socket as 99% of headphones use 3.55mm as standard.
I would check out the Hidizs as I own it and it is superb. you can put 2tb micro cards in it so can put wav or flac files on to it therefore not worrying about losing audio quality. IMO it is better than the Fiio x5 and X3.
regards
Rich
