Portable DAC for HTC One
BillyBoy58
Hi
Can anyone recommend a portable DAC that is small enough that I can connect to my HTC One Smartphone. I am looking to improve the quality of sound from the HTC. My playlists are from Spotify.
kind regards
SteveR750
I'm looking for the same for my S3, and considering a Hugo since this would also upgrade the home system too. Is there anything else cheaper as a portable DAC for a phone? I don't mind wired connections, but wanct a built in amp that's more powerful than the S3.
caesar44
89
Astrell and kern stuff tends to be pricey for what you get in my opinion. Have you considered the Fiio E18? it gets rave reviews from android users.
