craigtumilty:
TheMovie Juke Box feature of the Popcorn Hour or the Default UI is very poor imho. I previously had a WDTV Live and switched to Popcorn A200 for DTS-HD pass through and honestly hate it for music playback, you cant play a song and then go look for another to play next etc without stopping the song. Perfectly fine if you want to play album but i always like playing the song i want to listen at that moment and it might not be on that album
I found the video produced on the a200 was slightly better than the WDTV Live.
Just thinking though, does the Popcorn Hour use its own DAC when playing FLAC to pass through to a surround amp?
You are wrong my friend. When playing a song, press source and then click ok on the icon that comes up on the screen that looks like a book, you can then press return and scroll through your library. When you want to go back to the playing song, press source and then click ok on the audio icon.
As for the UI, an all singing, all dancing UI will be included in the firmware out this month. Similar to YAMJ but better.
