- Feb 19, 2012
- 129
- 0
- 0
Low wattage high current is better than hi wattage with limited current?
My Rotel 1520 (stereo)60watts per channel using both A and B speaker (bi-wire/bi-amp)to drive a pair of Mission 782se (6ohm/200watt)is not delivering low frequencies like I'd like.
With the recent change of interconnects the sound is better were the mids and tops are concerned. but those low frequencies are just not there.
The Yamaha AX620 90watts (A/B fronts) x5 theoretically can drive 450watts constant into 8ohms (total). This requires more current when things get dramatic. It sounds better in stereo - using A/B fronts as above ( all other channels turned off), making the Missions sing with a fuller dynamic range.
The Rotel go's louder in terms of...er...loudness but its not louder, if you get what I mean, you hear its loudness, but you feel the Yamaha's.
Having read a few of the post I had to ask this, how does it work?
