I know some of you out there have already delved deep into the MCACC / manual speaker set up of Pioneer AVR's (mine's the VSX-2021) so if you're one of those clever folks, I'd very much appreciate your help so I don't attempt reinventing the wheel.
HERE'S WHAT I'M TRING TO ACHIEVE:
Ever since the iOS 8 update, my AVR control app has failed to work. (Bad show Pioneer for failing to update the app - apalling commitment to customers who've given you their wads of money and a real shame as in every other respect, it's an amazing bit of kit).
One of the things I especially liked to do when playing 2.0 channel stereo, was to use Pioneer's Extended Stereo setting to play the signal through all speakers. What I used to do using the app, was to alter the fader about half way in favour of the front speakers. I used that screen with the circle and the dot in the middle and you could move the dot up, down left or right to affect the balance or fader of speakers. I used to set it centrally left to right (as I didn't want to alter the balance), but about half way towards the top of the circle to reduce the relative volume of the rear speakers.
The result just made music sound right to my ears from the listening position. You had the larger opened up soundstage by bringing the rear speakers into play, but they didn't overwhelm the mix to the point where you thought people were actually singing behind you (which would sound inherantly wrong).
So now my iOS control app is kaput, I'm trying to do this manually using different MCACC presets. I only want to use the affect described above for CD and Home Media Group sources, not TV or Bluray.
HERE'S MY PROBLEM SO FAR:
I can see from the manual how to alter the volume levels of each channel, and how to copy & paste memory presets from one to another, but what I can't figure out, is when you're altering the channel levels in the Manual SP setup menu, how do you know which of the 6 memory presets you're changing?
Do your changes only affect the memory preset and input that you happened to be using at the time? So for example, if the basic Auto MCACC is Memory preset 1 and I wanted to set up a new preset no.2 for the purposes described above, would I first copy Memory 1 to Memory 2 (to use as a baseline), THEN select the input I wanted to change, THEN select the MCACC Memory preset I wanted to change, THEN actually make the channel level adjustments?
Obviously I don't want to alter or override levels that currently work very well for the other inputs. I hope my descriptions made sense! Do you have any suggestions as to how I could accomplish my aims above? Any help would be gratefully received! Many thanks in advance.
