Pioneer KRL37V
Hi Spek are doing the KRL-37V for £880 with a 5 year warranty thrown in...
link
This issue about the uneven backlight is this common or an limited problem with some sets,also there has been some problem about the viewing angle,does that mean this could cause a problem if the tv was to go into the corner of the room.
Clare Newsome
1,657
I believe the uneven backlight to be limited problem, as i've seen other Pioneer LCDs without the problem. However, we call it as we see it!
Viewing angles of most LCDs are limited, to be honest - they're best viewed as straight-on as you can.
I have bought it. How easy is it to spot the uneven backlight? ÿWas there a lot number or batch number I should avoid or refuse?
ÿ
Tim
ÿ
