Pioneer BDP-51FD firmware update
The latest firmware can be found here, however I do not believe that it is profile 2.0 as you would need an ethernet port on your BD player for this.
This update gives the long awaitied support for DTS-HD.
i donno what this profile 2.0 is but the latest firmware is 1.32 and you dont need to connect it with the ethernet cable. you have to burn a cd to update it. i did it last week to mine...
so, what is the main different? is it shows in the display that it is now decode th DTS MA?
Thats what the new firmware update does.....
- Enables the following new functions
1. DTS-HD audio output
Enable to convert DTS-HD audio to linear PCM for HDMI OUT (MAIN) terminal.
Enable to convert DTS-HD audio to analog audio for AUDIO OUT (7.1 ch) terminals.
2. Crossover frequency for AUDIO OUT (7.1 ch) terminals
3. BD-LIVE
- Enhances stability of BD-Java playback (*)
- Enhances stability of BD-ROM/BD-R/BD-RE/DVD-Video playback
- Fixes an error of resume playback function after switching off the player by pressing STANDBY/ON button during playback of BD-ROM discs.
- Performance improvement
* The player's action can be slower than expected depending on contents (menu, game, etc.) included in certain BD-Java discs
