Pioneer AV5 app stoped working
Q5
60
Ian986 said:
Hi All,
Does anyone else use this as mine stopped working a few months ago and just cant get it to connect any more?
Just checked mine and it is working on the LX85
Leeps
219
My app's still running fine too. It could be a network issue. Try this;
Switch off your AV receiver (at the plug too, not just standby)
Reset your router. Most routers have a very small hole marked 'Reset' which you need to press with the end of a paperclip or something equally small. Keep it pressed in for about 20 seconds.
Leave your router to re-boot for a few minutes.
Then switch your Pioneer AVR back on. Then re-open the app and see if it connects. All the above has done is prompt your router to re-introduce itself to any devices showing on your network. It's worth a try. Beyond that, I'd double-check the connections of your ethernet cable to the router.
