Hi
Lost previous denon home cinema amp in a house fire recently - looking to get hold of an entry level amp for a replacement.
I'm looking at low to mid end amps - the one that's taken my fancy is the Pioneer VSX 923 - primarily I will use it to connect my iPhone Spofity account and Blu Ray player...
How does the connectivity work? Is it built in to the amp or do you need an internet connection from the amp to do this? The amp would be on a different floor to the wireless router and modem so its not easy to wire connect it.
I've also noticed Pioneer are launching the newer Series of VSX (notably the 924) - are there any notable differences?
Any info is greatly appreciated - as you can tell my know how of amps is rather minimal.
