George680 said:
Hello reader,
Just bought myself a really nice Rega RP10 turntable with Aphelion cartridge factory fitted.
Do you have some advice for me om what phono amplifier would be a good match?
Looking forward to haar from you
Regards
Sjors
Really?
You spent that much on a turntable and MC cartridge and then have to ask that question?
Apart from not mentioning what other equipment you are going to add this turntable to exactly how may people on this forum do you think have equipment of that level?
Without seeming to be an attack on ignorance I would strongly suggest this should have been asked of the dealer you bought the turntable from as we have no idea as to what you have available to audition wherever you live.
Did you audition the turntable before you purchased it?
Basically more information needed as to your current amplifier and what sort of budget you are looking at might help, and you may very well need it ;-)
Basically try to audition as many phono preamp that can handle low-output moving coil cartridges unless your current amplifier has an inbuilt phono preamp where a simple step-up transformer may be all that is required.
