PHILIPS 37 PFL5405H
Hello to all of you...i have just one question....im thinking of buying this LCD...i will use it for normal things...some sports,movies...normal watching....so i will be thankfull if you give me some thoughts,advices...thank you again....
where do you live ? a google of that exact model found a lot of foreign sites , if its the same tv as the 37pfl5604 , which i think it may be , then its a fine little tv , i had one for a few weeks , and couldnt fault it , once your not paying too much id say go for it , assuming its the same tv ..
uk price should be £450-£500 .. in euros ..e550-e600 ...imo.. any more and id factor in other models too ...
i dont know if that model that you are mentioning is the same as mine...
here is the link of my lcd im talking about....i think that it has good technical information.
http://www.pixmania.si/si/uk/4928255/art/philips/37pfl5405h-12-lcd-televis.html
well ive not heard of it , perhaps it is a new model as ear says , it has 100 hz too , at the price , thats quite a good deal , assuming its at least as good , and more probably better than the 5604 that i had ...
2010 range, as ear pointed out
All 2010 ranges end in 5
9705 etc.
I haven't seen a single one of these sets yet, although I know they are available in Holland, so someone must have one... Unfortunately it's only the 7 and 9 series that tend to get tested by most reviewers.
