Phase control
Hi MB
Your sub is in phase with your other speakers, when its woofer matches the "in and out" movement of the other front speakers.
How do you tell......If the sub is out of phase, it starts to cancel out the bass in the room, giving you less of it.
How to set......Try different phase settings, and use the one that gives the best bass when listening from your seat.
Hope this helps
Cno
ok, thanks. i'll have a fiddle and see what happens. thanks for your help.
