Panasonic wireless dongle
Has anyone used one yet? good report? what type? where purchased? I could ask you another for a bonus point, but I won't.
The Panasonic wireless dongle for viera tv's such as the G20 model to make them wifi capable is retailing around £79.99 and the model number is: DY-WL10E-K. As for any hands on experience, i cant answer that one as they are not available yet but due out very soon. Regarding where you can purchase one, i think you will have to go to an online retailer or an independant retailer who has a Panasonic account and get them to order you one, maybe they even might stock them.
M
I have a TX-P42G20 which, for the past three months, I've had linked by cable to an Ethernet switch. I've been trying to get it to work with a new D-Link GWA-140 wireless adapter, but attempting to access the menu to configure the wireless side rather than wired brings up the message No Adapter even though it's inserted into one of the USB ports.
Has anyone else had this problem?
One possible point is that I'm now using the third router in line since acquiring the Panny at the end of March, but the network configuration didn't need to be changed to use with an Ethernet cable.
Does anyone know if the dongle that comes with the BD85 Blu Ray player will work on the 46G20 Plasma. Is there any advantage setting up network functions using the TV rather than the Blu Ray player? (I'm a complete noob to the network side of things and not even sure if I'll tey and set it up)
There was one with my TV. All I can tell you is that it works, and that it tells me my software does not need updating.
