Panasonic S20 Plasmas - can someone advise whther they suffer from the reported problems
robstar63
21
Could someone kindly clarify whether the S20 range of Panasonic are known to suffer from the much reported problems suffered by the G20, V20 and VT 20. I am considering buying a 46 S20 as they are available at good prices at the mo.
Could someone also explain in very simple terms what the problems seem to be on the plasmas which do have the problems so that I can be more aware
What is posterization for example ?
Many thanks in anticipation
Regards
I have the 50S20B and I am very happy with it, I have noticed no posterization, rising black levels or the 3 Centre lines on quick pans when veiwing HD footie.
I managed to get mine for £ 749.99 a while back and it was a bargian at that price.
In terms of Posterization, see the quote below:
Temporal posterization is the visual effect of reducing the number of frames of video, while not reducing the speed at which it actually plays. This compares to regular posterization, where the number of individual color variations is reduced, while the overall range of colors is not. The motion effect is similar to the effect of a flashing strobe light, but without the contrast of bright and dark. Unlike a pulldown, the unused frames are simply discarded, and it is intended to be apparent (longer than the persistence of vision that video and motion pictures normally depend on). The effect is available in After Effects and other motion graphics and video editing software.[1] An animated GIF often looks posterized because of its normally-low frame rate.
More formally, this is downsampling in the time dimension, as it is reducing the resolution (precision of the input), not the bit rate (precision of the output, as in posterization).
The resulting stop-go motion is a temporal form of jaggies; formally, a form of aliasing. This effect may be the intention, but to reduce the frame rate without introducing this effect, one may use temporal anti-aliasing, which yields motion blur.
I have the 42G20 and have had no such problems!
I would probably take some of these rumours/reports with a pinch of salt, the Panasonic plasmas are some of the best on the market, taken over from where Pioneer left off. So building on years of innovation and quality.
