Panasonic remote operating 2 dvd players at once
Hi
I have a blu ray & dvd recorder - both Panasonic.
Problem is when I press play on the remote for the blu ray it also gives the recorder the same command.
Is there any way to stop this happening ?
If you still have the manual for either, there should be a fix. It is on page 33 of the BD35/55 manual. .
1. To instruct the BD player:
Press Setup
Select General, press OK
Select Remote Control
Select one of the Set Code - try 2
Press OK.
2. To instruct the remote:
While pressing OK, press and hold the numbered button (as above, say 2) for 5 seconds
Press OK
That should do it. I have Panny BD and DVD players and was able to separate the remotes and devices.
