Hi. First of all, watts themselves don't matter as much as you think they do - a 100W amp will only sound 3decibels louder then a 50W one. Each time you double the watts you get a 3db increase.
Secondly, if your listening area is a normal room (meaning 16-twentysomething square meters) any of those amps will do imo.
Thirdly, out of those three options, only the Outlaw is a reciever, and a neat box of tricks - the other two are just integrated amplifiers. Since you wanna listen to music from a computer, then you need a DAC (digital to analogue converter) to make it sound ok, since pc soundcards are usually bad. The only one of those amps that has this feature is the Outlaw. It also has a phono stage if you later wanna add a turntable, AND a radio. And a kind of EQ. Sounds like a really neat sollution.
Now, your speaker's specs say they have a 90db sensitivity, which means they are pretty easy to drive speakers (they don't require a lot of power to sound loud). So you could look at any amp that tickles your fancy, provided your room isn't huge and you don't wanna make a disco out of it. But, for that price, you won't get that kind of functionality and features. Maybe Marantz MCR610 (or the new 611) - some people that use the Polks you have seem really pleased with pairing them with Marantz.
Other recommendations I would make, besides Marantz PM6005 (or 6004), would be Arcam A19 and Roksan Kandy K2 - but these would mean you'll have to get a separate DAC - such as the Micromega Mydac - in which to plug your laptop/PC and cd player. And separate radio of course.
Also, from reading around, the Polks seem to be bright-ish sounding speakers, so you should pair them with warm amps that have smooth highs - I would stay away from Cambridge Audio.
