optical help
bonenut
9
hi,can anybody help.i have never used optical leads and decided to try it out and connected a optical cable from my primare dvd 26 to an external dac(marantz hd dac 1)to see the results and i am not getting any signal.unblocked is coming up on the marantz display(which means in the manual that no signal is received)i also connected the same cable to a teac ud h01 dac and am having the same results.
when i unplug the cable from the dacs there is light coming from the cable end,so i assumed that that was a signal.can anyone help.the rca analog cables are connected and the amp is getting a signal and is outputting to the speakers.is the fact that the rca is outputting and can only output on one output?...
bonenut
9
thanks lads,only problem is i dont have the original remote.i have a one for all,i will see if i can get the menu up on that.cheers.
