Hi guys, been out of the upgrade game for a while so my question is this; Would the new oppo BDP 103D represent an upgrade over my current player the Denon 2500BT?
michael hoy said:Hi and welcome.
I am not sure of the Darbee element of the OPPO (D), I had the 2500BT for a long time and now own the OPPO 95.
Depending on whether or not you want / need the extra features and of course the HD audio, picture quality wise the OPPO 95 is better but not night and day.
Personally I would change from a 2500BT to an OPPO again, but maybe save some money by not buying the 103D and get the 103.
Can you demo?
JASPER09 said:Will probably be getting one of the new consoles later in the year, not sure which one though.
BIGBERNARDBRESSLAW said:8 G D65 HDMI Settings.txt
I'm pretty sure these are the settings I used, hopefully the link will work.
Yes from reviews I've read the 103 is a good player with which is the player I was maybe thinking of getting however, other reviews I read for the Denon 3313ud say that it slightly bettered the 103 and these comments where from other 103 owners. Looking at the quality of the 3313 I'm not surprised! So i was happy with those reviews as I personally love the look of Denon players, as it is my preferred brand.gel said:michael hoy said:Hi and welcome.
Can you demo?
Agreed, 103 is a good player.
I've also owned / demo'd high end / budget players also and my conclusion is different to yours.Mtenga said:You ask where people came up with the conclusion that there is no difference between budget and high end then I'll say the answer is by owning them. I recently sold a Denon 3313, and currently own a Pioneer 450, Panasonic 130 and PS3. There is no meaningful difference in bluray between any of them and the difference in DVD is marginal at best. The Denon cost ten times the Panasonic and nearly three times the Pioneer.
The only real difference is price, file support, features such as MC analogue and build quality which may or may not be of value. The Pionner at 180 does everything that the Denon at 500 did, since they are both transports, but is not as well built. In fact it works flawlessly which is more than can be said for the Denon which had issues. As others have said upgrading the AVR, TV and Speakers is going to show more performance gain than buying an expensive player. Bar build quality and features 500 quid plus transports are just about fashion to me.
