- Aug 10, 2019
- 2,556
- 5
- 0
Hello,
I've just bought myself a new Onkyo 706. I've got 5 satellite speakers (HKTS11) connected to it and they sound great, but I'm having problems with getting the sub to work.
The sub is set to "on" (instead of "auto on"), the volume is set to the mid-position, the filter is off and I run a coaxial RCA cable between the low-level-in on the sub and the sub pre-out on the onkyo.
I've tried different cables, tough. Nothing seems to work.
At first I tought the sub died on me, so I connected it at minimum volume with the filter on directly to the analog output of my DVD player and I DO get a humming sound out of it. So the sub ain't broken.
I've tried every setting on the onkyo. I also double-checked the individual speaker settings and crossover frequencies.
Last time I checked I had my front, center and surround speakers set to 120Hz (front was preset at full-band, but I disabled that). The sub option is set to "yes" and the sub crossover frequency is set to 90Hz.
I get test tones out of every speaker when doing manual or automatic calibrations, but none whatsoever from the sub. I also fiddled with the individual volume setting of the sub, thinking it might have been put to low. I turned it up to the max. (+- 12dB), but still I don't get anything...
I'm feeling really desperate now, since the thing going wrong seems to be a defective sub pre-out on the onkyo.
Has anyone experienced this before? Or am I missing something totally obvious?
greetings,
Dries
greetings,
Dries
