Onkyo TX-NR609 with B&W 685 theater speakers with ASW610 subwoofer or Monitor Audio BR5, BR2, BR-LCR and BR-W10 ???
  • Thread starter Thread starter OK
  • Start date Start date
OK
10
Kindly I need someone's advice about which speakers to pair with Onkyo TX-NR609.
Should I go with B&W 685 theater speakers with ASW610 subwoofer or Monitor Audio BR5, BR2, BR-LCR and BR-W10 ???
I Live in Amman Jordan.. there is no way on earth i can listen to demo of the 2 setups 🙁((
Room size is 6.7 meter x 4.5 meter...
I'm kind of a perfectionest....
Cheers 🙂
Even though I am a big MA fan, out of the two set ups I think the B&W's would be head and shoulders above the BR range. My only suggestion would be to consider an AVR in the next price/performance bracket if you can, as I doubt the 609 (although it's a great machine) will do the 685s justice.
Unfortunatly I cannot get my hands on a better deal. Well the Onkyo 609 delivers 100 Watts per Channel at 8 Ohms... and B&W 685 handles power from to 25W - 100W into 8 ohms.....
Will the B&W 685 theater sound better than the MA???.... Although the BR5 can handle more power and they are way bigger...
should I take into consideration the 709 and 809? or you mean AVs from other manfuacturer to suite the B&W???
will this make a big sound details difference???
Many people comment that the BRW10 was a bit of weak link. Myself I found the BRLCR not really up to the rest of the BR range.
Is the newer Monitor Audio BX range an option ? Maybe to save a bit you could use the BR1 or BX1 for rears rather than the 2s.
Never heard the 685s, but being a B&W fan they might be a safer bet.
There is a forum member who has the BR range but uses the BX CENTER, hopefully he can help you out.
I demoed the br5 and the 685, and much preferred the br5 due to it's better bass.
What Richard said about the BR sub is correct, the REL I ended up with was much better. I would also say the br2 is too big a speaker for the rear, go with the br1 unless your room is enormous.
I have the bx centre, which is great, but have never tested it against a BR centre as I couldn't find one.
thank you guys 🙂 for your replies....
my mistakes the speakers is not BR series they are all BX series.
the MA speakers are going to cost me like (BX5,BX2,BX center,and BXW10) = 1300 pounds
the B&W speakers are going to cost (685,686,HTM62,and ASW610) = 1450 pounds
I've heard that the MA are great speakers yet it's not that great with a bit low quality AV sources ???
need some advice about the AV receiver....
I mean which amplifier to better pair these speakers with..
I'm considering the Onkyo 709 now
thank you so much 😀
Cheeers
