- Aug 10, 2019
- 2,556
- 5
- 0
I use my Onky 606 with my V+ box (kit as below).
I used to have to keep the volume at 30 to 35 for loud viewing (under 30 for background).
Oddly, after turning it on one day it is now about 40 minimum, and up to 50 for decent viewing. There seemed to a blip at the same time, where I was only getting sound through the centre chanel.
It has now settled down and is just much more quiet?! Have I accidently changed anything on the set up? I had swapped from hdmi to optical for the sound, so I may have changed something that has caused this (although after the change it was fine for at least a month!). It can't be the change itself as I have reverted back to hdmi to test and it is just as quiet.
Why has it suddenly lost about 50% of the volume?
