Olsen - Sounds Fantastic Mains Extensions
I have been trying to find an 8 plug extension for a while and came across the Olsen Sounds Fantastic which look pretty good, has anyone any experience of them ?
http://www.soundfantastic.co.uk/products.htm
aliEnRIK
92
Yeah ~ I have one
Very good for cleaning up tv pictures, not so good for high powered amps
jase fox
212
Yes im currently using one, like Rik said it certainly does good justice to TV pictures & i find it to be a good all rounder, im very happy with it.
Cheers lads. I know it's probably against all known laws of physics (or something) to use an 8 plug extension but it would be absolutely ideal for how my hi-fi is set up at the moment. Does it have screw holes at either end for attaching to a wall ?
Spacehopper:Cheers lads. I know it's probably against all known laws of physics (or something) to use an 8 plug extension but it would be absolutely ideal for how my hi-fi is set up at the moment. Does it have screw holes at either end for attaching to a wall ?
Thinking a mains extension can affect the performance is against all known laws of physics, but that's homeopathy for you.
jase fox
212
Yes it does have screw holes Spacehopper, id get one as its great value.
Gwyndy
Red Dwarf:Thinking a mains extension can affect the performance is against all known laws of physics, but that's homeopathy for you.
Science is limited by our ability to carry out empirical observation and the equipment available for its use, therefore to state that something is against the laws of physics does not by definition mean it cannot happen.
