Craig M. said:He is using the analogue (and optical - does the AVR have a dac?) from the sonos.
Yes, it does have a dac, and IMHO quite a decent one, for it's age.
scene said:Interestingly, the dv79 sounds fine... :?
Craig M. said:Am I the only person whose noticed he isn't using the dvd player as a source in this comparison? He is using his sonos units connected via optical and analogue.
CnoEvil said:Craig M. said:Am I the only person whose noticed he isn't using the dvd player as a source in this comparison? He is using his sonos units connected via optical and analogue.
IMO What ever is being used a source is possibly being shown up by A85 / MA.....IMO. Worth checking out.
Craig M. said:Again, apologies if I'm reading it wrong, but I don't think he's mentioned using the A85 with the MA's. He is comparing the cheap Pioneer surround amp with the Arcam surround amp. His sig mentions the A85 is being used with some AE1s.
CnoEvil said:Craig M. said:Again, apologies if I'm reading it wrong, but I don't think he's mentioned using the A85 with the MA's. He is comparing the cheap Pioneer surround amp with the Arcam surround amp. His sig mentions the A85 is being used with some AE1s.
You're probably right.....I'm on a fair bit of medication at the moment....so the wrong end of the stick is easy to grab! 😳
Craig M. said:Thank god for that. I thought I was cracking up!
That's why I said he should try the A85 with the MA's, if it perks them up he knows what to do - replace the AVR250, or replace the MA's with some much easier to drive speakers.
I hope your back rehab is going well, even if you are beyond help as an audiophile. 😉
scene said:But, on previous comparisons the sonos attached to the avr250 sounded very similar to the dv79 attached to the same. Now, the dv79 sounds much, much better than the sonos. Which is odd.
CnoEvil said:scene said:But, on previous comparisons the sonos attached to the avr250 sounded very similar to the dv79 attached to the same. Now, the dv79 sounds much, much better than the sonos. Which is odd.
.....and probably what I would expect.
scene said:+1 on the back getting better.
CnoEvil said:scene said:+1 on the back getting better.
Thank you.
Maybe you are in your personal episode of The Twilight Zone! :?
scene said:Sorted - I am no longer in the twilight zone! :bounce:
I am however in the doghouse... :whack:
Having spent some not inconsiderable amount of time with kit shuffling I finally got to the root cause of the problem. Me. 😳 I had, at some point changed the settings on the Sonos connected to the main AV amp from "Fixed" to "Variable". And I have now learnt a lesson, even with the volume on Variable set to full, the extra volume controlling / equalisation hardware in the Sonos it goes through really mulches the output. With it set backed to Fixed, the Arcam AVR250 now sounds at least as good as the Pioneer. Which is nice.
