Hi, I am looking for an integrated amplifier for my Vienna Acoustics - Bach Grand speakers. For the last 6 years I have used Cambridge Audio 840E + 840W, which has worked quite well. I used to put + 2 dB on bass and - 1 dB on treble, to remove some of the fatiguing cymbal treble on poorly recorded tracks, and add some bass to make the metal-music that I listen to more fun. I only listen to power and some death/black metal with a lot of less well-recorded albums. Because I have a new heat efficient apartment, the heat produced from my Cambridge 840W was annoying and therefore i decided to try a Class D amp.
I purchased (second hand) a Nad M12 and M22 based on reading reviews. Unfortunately the Nad M12 and M22 made my speakers sound more like studio monitors, and now I have not listened that much to music as it do not sound that pleasant. The treble is more present, mid-bass dissapeared (I believe) and vocals seem thinner... although the bass was more thight and zero sound/humm from the amplifier itself. Some years ago I also tried a Rega Mira 3 and Marantz PM-something, and from memory they sounded better (which doesent make any sense?). Since the Nads have a high price and I don`t like them that much I have decided to sell them and buy something cheaper. But what amps should I try?
I am not sure if I (due to heat) should try another Class D amplifier, or if I should try A/B. I want an amp with USB, preferably an integrated. The amp cannot be to heavy (max 9-10 kg), due to my back problems. From what I read the NAD356bee seems to fit, but it looks uglier that a drunk troll (I prefer brushed aluminium fronts). The Cambridge CX80 seems ok, but is it less bright than Marantz PM-7005? Which has a 'fuller' or heavier sound? Any other suggestions?
Samples of what I mean with bright/less good recording: 1) Neonfly - Outshine The Sun, 2) Helloween - Save Us, 3) Arch Enemy - Ravenous
Edit: Is the Nad D7050 an option? Does it have enough power to drive the Bach Grand (4 ohm) in a 23 square m room?
