New system needed for small room and tight budget!!
Loczki
16
I am a new student at uni and after 3 days of listening to music throught laptop speakers i have decided i need a real hi fi system. My budget is about 200 pounds, but i might be able to stretch that quite a bit further if necessary. Ive been looking at the Tannoy F1s, as i had a pair of F4s and i havent had many problems, the main problem though - is the room size. I will need a pair of speakers that wont be too bad up against a wall or in a corner, and an amp that goes well with them, as of now i dont need a tuner or cd player, if anyone can help it will be greatly appreciated.
Regards
Aleks
NAD C315BEE £199 (less in some places) and something like Wharfedale Diamond 9 for about £70 maybe.
You can plug your iPod/MP3 straight into the front panel on the NAD and your laptop can plug into a spare input on the back with an RCA phono --> 3.5mm jack lead.
Later you could save up for a DAC or iPod dock or speaker stands as and when funds and room allows.
Great little amp and can equal or beat 400£+ amps...
http://cgi.benl.ebay.be/YuLong-Audio-AMPONE-Power-Amplifier-AMP_W0QQitemZ160297609206QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item25527b67f6&_trksid=p3286.m63.l1177
A review...
http://dood.ca/2008/09/26/yulong-amp4780-integrated-amp-review/
Try speakers like Dynaudio, Klipsch or Wharfedale on this unit and it should be a good match, and from my experience in comparing stuff in searching price/quality you can have very good hifi for little money.
Only downside, it has only one analog in for a source.
My setup is 10000£+ in my living room and is a bit better, muscular, authority and finesse by selecting and matching components, but in a not to big room, my bedroom, i use this little amp with sensitive speakers like the ones i mentioned and it's an immediate listening experience.
It beats my 10000£+ set up miles in price/quality.
Got mine from here...
http://myworld.benl.ebay.be/snow48_6/
You can always ask for it, got it cheaper there also and good service.
My wharfedale's where at least a better match on this then some very expensive stuff i tried them on.
But it's ok, i'm used to negative reactions with stuff people don't know, their loss i'd say.
Pioneer A400 amp ... old but good ... dont pay more than £120 (I got mine for £70-mint and boxed)
IMF 3 way compact studio monitors .... old but good ... ebay item 260482328385 ... buy it now = £75
