Apologies if this appears twice - I just tried to post but it seemed to disappear.
Anyway, I'm new here and feeling out of my depth so please bear with me...
My current system is pretty old but in good nick and still doesn't sound too bad to me. The amp is an Aura VA100ii which I bought from a friend a few years ago, and some Kef Coda 7's which I bought new many years ago. My main source these days is a Squeezebox Touch playing FLACs. My secondary source is another vintage component - a Linn Axis turntable.
I am putting together a cheap system for my office, with a Raspberry Pi/Wolfson DAC-based Squeezebox as source. I was looking for some cheap speakers to go with one of these T amps that can be had for £60 or so (e.g. the Topping TP22) and came to the conclusion that my best bet might be to use my Coda 7s as (i) they are pretty sensitive, (ii) they do have a few scuffs on the cabinets and (iii) it gives me an excuse to upgrade the speakers in my main system, which is something I had always had in the back of my mind but never got around to.
So, first of all, bearing in mind that I am more or less clueless and am just a music lover who has dabbled in hi-fi over the years does it make sense for me to stick with my old amp and upgrade the speakers, at least for now? I've done a bit of googling and it seems like at least some people still rate the amp.
Assuming it is a reasonable plan, what speakers should I consider? I don't even know where to start so I'll outline the constraints. I can afford up to £500 but will only spend that if it is worth it. The amp tends towards the warm side (I saw someone describe it as having some valve-like characteristics, though I wouldn't have the experience to say whether that is true). The room isn't large - about 4 x 5 m into alcoves etc. - and there isn't a lot of space to play with. I can't afford much space between the speakers and the wall. Generally I need something that isn't too big nor too fussy about placement. Almost certainly I am looking at stand-mounted.
My music tastes are varied and include rock (in its broadest sense and tending towards older, 60s/70s type stuff like prog and psych), jazz, folk and orchestral classical. I'm not into dance music, modern electronic, that sort of thing (i.e. thumping bass is not on my list of priorities!). In general, I tend to like music where there is a bit of space and you can hear the instruments, rather than anything that is highly processed and artificial sounding.
Hopefully that is enough to get started. Any advice would be greatly appreciated.
 Facebook
Facebook Instagram
Instagram
