New setup KEF LS50 with NAD D3020 or B&W 685 S2 with Rotel RA-12
raiders4life12
What would offer a better value and sound for the price: KEF LS50 with NAD D 3020 or B&W 685 S2 with Rotel RA-12
I have a large room and listen to mostly classical with some blues and rock. I don't need a lot of bass and I plan on listening at medium levels.
My budget is between $1500 and $2000
Also any suggestions on good integrated amps for the 685 or the LS50 within my budget would be appreciated.
Thanks in advance
Frank Harvey
567
Based on the fact you have a large room, I would be leaning more towards the Rotel/B&W combination, despite preferring the sound of the LS50s. I think the NAD may struggle with the LS50s at higher volumes - although you don't say just how big your room is...
wilro15
74
Haven't heard those particular B&W/Rotels, but I have heard other models of B&W and Rotel and it usually sounds pretty good.
I used to own the LS50 and they need a much better amp than the NAD D3020. They may be small, and relatively inexpensive, but they need some serious grunt to get the best out of them.
knaithrover
217
89
18,870
As previously said I think the LS50's are a bit over the top for the NAD very talented though it is. That said I have just tried mine with some very power hungry Boston Acoustics M25's and it seems to be managing admirably pushing out quite a bit of grunt without losing much in the way of finesse.
raiders4life12
Some other speakers and amps I have been considering are
Monitor Audio Silver 2
Totem Dreamcatcher
Dynaudio Dm 2/6
Peachtree D5
Focal Chorus 706V
Amps:
Marantz PM7005
Cambridge CXA80
Peachtree nova125se or 65
NAD C356DAC
NAD D 7050
What are your opinions on these and how they would work together?
