Deleted member 2457
https://translate.google.co.uk/translate?hl=en&sl=no&u=http://www.tek.no/artikler/5-ting-som-blir-bedre-pa-neste-ars-oled-tv-er/193623&prev=search
gel said:https://translate.google.co.uk/translate?hl=en&sl=no&u=http://www.tek.no/artikler/5-ting-som-blir-bedre-pa-neste-ars-oled-tv-er/193623&prev=search
Huh?Series1boy said:gel said:https://translate.google.co.uk/translate?hl=en&sl=no&u=http://www.tek.no/artikler/5-ting-som-blir-bedre-pa-neste-ars-oled-tv-er/193623&prev=search
has your account been hacked?
What are you using? I am using my iPad and it works fine.Series1boy said:When I click on the link it takes you to an oversized google translate and I can't see a thing...
gel said:What are you using? I am using my iPad and it works fine.Series1boy said:When I click on the link it takes you to an oversized google translate and I can't see a thing...
gel said:Try here:
https://www.avforums.com/threads/lg-2016-oled-tvs-improvments.1988233/
Yep, you click on it and then scroll down to find it.Series1boy said:That works mate. What was the other link, have you tried the first 1 you posted from the thread? It takes you to google translate...
