Need some turntable advice
AtBs
8
Thanks for the encouragement Steve! So, here it is a more detailed description of my actual system:
- amplifier ROTEL ra 1520,
-power amp ROTEL rb 1552,
-speakers B&W CM8.
As I said,I´m thinking to purchase a turntable to use it as an analog signal source for the mentioned system. Actually,could be any other device which offers a clear and natural sound.Allocated budget 400€-600€.
Any suggestion?
AtBs
8
Hello again! Also I have an iMac ,2010 model. Can it be used as a CD player or media player for flac files.I don´t know if the sound chip(card) is good enough to obtain a quality sound.
Is there anyone who have knowledge in this area?
Thanks!
ifor
115
12
18,595
You can use the iMac to play ALAC files from iTunes, or FLAC files with a third party iTunes plugin. Ideally you would want an external DAC but the iMac isn't too bad without.
