Need Help With My B&W Speakers
Have B&W Following Models
Front😀M602 S2
Centre:CC6S2
Rear😀M303
No Sub Yet.
Totally confused with the amp silection.I do understand i have to have a AV amp to get my centre channel to work.Everyone telling me if im into music CD's Is better to go for Sterio amp.Like NAD or Rotel is the best match for B&W speakers.I dont mind paying 300/400 pounds but love to have my centre channel working.
Someone told me i can buy sterio amp and buy another AV amp with pre amp to process my centre channel. AV from denon with pre processor is quite expensive anyone have any idea.............what should i do..
Q.1.What Sterio AMP Gonna Be Best For Me?
Q.2.Spending That Much Money Does it worth to have my centre channel worked ?
I think the key thing is to decide on your main priorities - what, in your opinion, is the system going to be used for mostly, listening to music or watching movies? If you're going to do both, which would you be happier to compromise on, the music performance or the home cinema performance?
My Priority Is Music so forget about Cinema. Well I Will Go For Sterio 2(Obviously A&B as i have 4 speakers).I
read some review about Rotel Rotel RA-04SE For 300 pounds sounds good
but no remote. Ok Make It simple for me is it NAD,Rotel or what ? which
model no...And how i'm gonna check my speakers with those amp.Cant just
take all my speakers down there.
I Will Appreciate If U Can Help Me Please.
