M markyboy156 New member Jan 5, 2010 203 0 0 Visit site Sep 7, 2013 #1 :cheers: hi i need wall brackets to mount monitor audio rsfx rear speakers can anybody please tell me what brackets would fit the bill that i need need help asap please :cheers:
J jonathanRD Well-known member Jan 27, 2011 179 52 18,670 Visit site Sep 8, 2013 #2 I assume you cannot just use their back fixing plate to hang directly onto screws fitted to the wall? I have the BXFX and I have them fitted directly onto the wall as above.
B Ben K. New member Nov 6, 2010 54 0 0 Visit site Sep 9, 2013 #3 +1 I have my RXFX mounted on screws as intended by MA and I used to mount my old BRFX exactly the same way,
M markyboy156 New member Jan 5, 2010 203 0 0 Visit site Sep 14, 2013 #4 :cheers: will these wall mounts do the trick Vogels VLB 200 wall mounts?
