need a new blu ray player
audioidiot1
40
hi all my blu ray player stopped working this morn so i need a new one.i have a budget of 200 to 300 quid wot would you reccomend cheers
Sony BDP-S360, Pioneer BDP-320, Panasonic DMP-BD80 - what does your kit consist of?
There is quite a few to choose, You have the Sony's the S360 around £80 - £100 and the S760 around £300. Also Pioneer BDP-320 around £300 and if you have Panasonic equipment and want to use the Viera Link feature, there is the DMP-BD60 around £160 - £170 or the DMP-BD80 at around £250.
Regards> M
thanks for your replys. setup consists of onk 577 and tannoy sfx speakers ixos hd.very happy with the way it performs.cheers
Whats your screen? Try get a demo of some of the above mentioned players with your screen- ( if it's not to old ) or one similar
audioidiot1:that was quick its a samsung 40 in rosewood 1080p with 100hz motion plus cheers
If you have the funds id audition the Sony S760 and the Pioneer BDP320, they would be sweet with that tv.........
hi boss it seemsto be sticking at 3 seconds,tried with a few blu ray and dvd and all the same. its maybe 3 years old.
i think it needs to be less than two years old to claim against it , do you have any plans to upgrade your tv in the next couple of years ?? if so , id get a sony bds360, their very good , you could then maybe move it to a bedroom and replace it with a 3d player , should you go down that road , only £80 , and works perfectly , pin sharp pic on my tv anyway....
hi max.no i,m not going to change my tv until it breaks.i bought it nov 2008 for my b/day (£900)and lost my job 3 weeks later so its stayin for a while as the wife would go nuts. i might just buy it as its cheap and take it from there
it sounds like the sensible choice , my friend has a 40a656 sammy , very nice tv , lovely sharp pic , i dont think you would gain much over a 360 with a 40in tv anyway . if at all...
audioidiot1:hi boss it seemsto be sticking at 3 seconds,tried with a few blu ray and dvd and all the same. its maybe 3 years old.
Silly question perhaps but have you tried a laser lens cleaner?
