Naim adds 24/192 support to Uniti range, plus AirPlay on its way?
AirPlay capability will make the UnitiQute a viable proposition as an upgrade (for me) so long as the price is kept around £1400 between now and Naim's usual price hike in April*. (My hifi spend 'window' is usually mid March).
Hopefully it will have all the functionality of AirPlay that I enjoy now on the Marantz.
*Otherwise I may not be able to afford an iPad 2 to go with it 🙂
Scissor_digits said:
chebby if you read the third last paragraph of the article you may be slightly dissapointed
£250 extra for AirPlay compatibility?
Forget it.
[Edit: Although... would a £79 AirPort Express - connected to the internet router with ethernet and to the UnitiQute with optical - make it AirPlay compatible without spending out an extra £250 and waiting for Naim to offer an expensive AirPlay download?]
S'what I do...
