nads question for you..nad C355BEE PRE-OUTS
biggus_1961
53
i would like to connect my denon 2106 av amp to my nad 2 channel amp..i know i can use the denon l/r pre-outs but do i connect those to the nad's pre-out 1 or pre-out 2. the nad book is a little confusing on this..i also have a cd player connected to the nad amp. i would like to operate the nad and cdp as normal without having to reconnect anything...Nad have 'jumpers' between mains in and pre-out 2, if i remove the jumpers per nad's book does this then disconnect the nad pre-amp section from the nad amp section ? which i dont really want as the stereo pre-amp in nad is better for cd play back....Hope 'nads' or some-one can help.
well first off you do not want to be conecting pre outs to pre outs. BANG
Out to ins,
what are you wanting to do use the nad for the fronts in the AV set up? then IIRC the AV pre out to any NAD line level IN.
You don't connect the Denon's preouts to the preouts on the NAD, but rather to a spare line input, such as the Tuner or Aux input.
