NAD C315/316 owners
eggontoast said:
MCRetina, did you try some RCA attenuators ?
Im working on it, I cant find RCA attenuators in Mexico. I will order from Amazon in case i dont find them and lets see how it works.
I think its a good option.
[/quote]As previously mentioned the imbalance at low volume is usually down to the volume pot not tracking together. One way to get around it if you do a lot of low level listening is to get some RCA attenuators and fit them on the inputs, this then moves your listening range to a higher setting on the pot where it tracks better.
The NAD C315BEE is unusual in that it has an internal adjustment for low volume settings. I am guessing that when your amp is returned from NAD that they will have just tweaked this and balanced the channels better.
[/quote]
Finally
I smuggled some attenuators to Mexico and they do the job perfectly, I bought 12db ones and they are a bit to efficient (they attenuate a lot probably 6db for the next time)
I don’t notice any problem in sound quality
Thanks for the tip
By the way, NAD support never accepted that the amp may have tis problem of balance at low volume.
MCRetina said:
Finally
Thanks for the tip
Glad they worked out for you.
