josh05:thanks stagea i have spoken to you before in another forum and u told me this, thats why i reckon the pre/power amp combination is defiently worth it, i want to get as much potential out of the cm's as i can. Still would like to audition rotel or cambridge audio 740 series but its a 2 hour trip to the dealer.
Hi Josh,
Yeah, I think i remember that. I see you've upped your amp budget by quite a bit. 🙂
If you have the budget for a separate pre/power, then you should be looking higher up the price scale for your amp. The C165BEE/C275BEE would be a lot stronger than the 740A (it's still considerably stronger than the 840A).
Choose among entry level separates (like the C165BEE/C275BEE) or premium integrateds in the same price range. The higher end integrateds would most likely sound better at moderate volumes, but the high power separates will fill a big room and would give you the dynamics that the CM9s are very capable of delivering.
