I'm planning on buying a new Hi-Fi and have demoed a couple of amps and loudspeakers. I've also read a couple of reviews, forum posts on these. I'm pretty close to making a final choice, but was wondering if anyone had any experience with any of this gear, if someone considered the same options or owned these devices, what your general impression was, if you're satisfied with your set and whether you think the amp/cd player is a good long-term investment.
These are the amps/CD-players I'm considering:
- Marantz PM15S2 & SA15S2
- Music Hall A70.2 & CD35.2
- NAD C 375BEE & C 565BEE
The speakers:
- B&W CM1
- Dali Ikon 2 mk2
- Boston Acoustic M25
Maybe a couple of you may think that the loudspeakers are a bit cheap for the amps, but they are more or less temporary and should fit in a small room. Later, I'll definitely consider more substantial speakers.
My choice will mainly depend on the sound of these devices, but I'm hoping to make an informed decision, so any comments you may have on these products (not only sound, but also durability, features, etc.) are welcome. There's a lot of information available on some of these products, but less on others (like the fairly new Music Hall).
A final note: the Marantz is obviously more expensive, but I can have it at a significant discount (new). Previously I was considering the pearl lites. Price aside, does anybody see a reason to pick the pearl lites over the Marantz?
Anyway, thanks a lot!
The speakers:
- B&W CM1
- Dali Ikon 2 mk2
