My new set up - Mk2
index.php
Lost the pic Lol
Solved the upload problem.
This is the finished (I hope for now? Lol) naked setup. It's been evolving for many years
Looks great!
All I need is a glimpse of yellow Kevlar and I'm sold.
Yea I know. I need to master the camera as well lol The kevlar looks better in the flesh
I prefer the covers on the speakers. Keeps the dust off the cones as well
Anyone got any ideas for hiding the cables behind the Sky box?
Thanks F1only - Rack is from Stands Unique with an extra shelf so that I can keep all the kit below the speaker.
Cable tidy - Thanks I'll have a look. The cables I want to hide behind there are very unflexable ie. Wireworld mains, Merlin Terantula, Chord Hdmi etc etc.
I was wondering about trying to find a piece of black glass (so no fire risk) cut to fit with a 2" or 3" slot along the bottom to allow the cables into the Sky box. Just an idea but not found the glass to do it......
The cable tidy then may not be suitable then, unless maybe you can get hold of a nice thick one its probably the cheapest option. You could go to a glass or windows shop & get one made up i would think to your specifications. I had a glass cabinet made up for my f1 models made by a local glass company a few years ago now & it cost me £100
Very nice!
Whatever you use to cover the wires at the back I would consider making it white so that it seems you are looking through to the wall behind.
Ah now that's a good idea about the colour
You're correct it would look better if I matched the wall colour.
Found a local company who make and cut glass for kitchen splash backs, plasma/lcd/led tvs etc. They have asked for the measurements. Got a choice of about 30 + colours. So will measure up and get a price.
Can't think it's going to be much for such a small piece to fit behind the Sky box. The cabling is an issue here because I have to have the Isotek on an upper shelf hence all the mains cables appear.
As per every set up there always has to be a compromise. TV is set up for the best seats in the house, so everything has to fit around that. Just glad there is no fireplace as it would have to be filled in.
To the left is the wall at right angles. So I'd rather have a sub in the corner than a main speaker. So sub is angled out to minimise any adverse effects from the corner and the settings changed to corner set up. Which is why I didn't get the PV1 sub as this may have caused issues.
Slight toe in on the mains produces a good stereo effect with the sub kicking in for all sources.
When I next move I'll be buying a house to fit my Hifi (I hope)........not the other way around lol.
Got a quote for piece of glass with a cut out to allow the cables through to the sky box painted to match the wall colour. They can match any colour.
£150 incl vat. I'm happy with that
So couple of weeks to make and I'll post a new picture
Very very nice looking set-up, always had an eye for stands unique racks, some can be quite expensive...again all looks great, Benny.
Thanks.
Upgraded the ethernet connections yesterday as wireless was just not efficient.
Put in an ethernet splitter box and hardwired the receiver,tv,bluray and sky to that.
This solved the iPlayer connection issues straight away. Cheaper than buying numerous dongles too.
Hi Marnie
That's a cracking set up you have there and you've obviously put a lot of thought into what you want and how you set it all up. I agree with you about using Ethernet as an alternative to wireless. Using well-shielded cables are always better that using wireless, as you reduce the chance of noise entering the surrounding cables and equipment.
Dave
Hi Marnie
Dave
