My IPhone 14 Pro’s battery is merely a day now!
Gel
1,557
591
3,570
Can anything be done about battery life, or do I cut my loses and trade in for the iPhone 16e? And that’s is a day of not using it!
My niece has just looked at the battery capacity and it’s still 97 per cent, and she doesn’t think Apple will change it at the moment.
They test it first and won’t replace until below 80%. At least that was the story with an iPad.
They didn’t actually replace the battery, they swapped the entire device for the battery cost. But a local’ fix it’ shop somehow prises the case open to change the battery.
Reactions: Gel
if its 97% it should fine in settings on the phone turn on battery saver this will stop apps working in the background extend battery life but you will have to turn it on again every time you charge it .dont let the battery drop below 40% and only charge to 80%. ... Sorry its called low power mode .
Reactions: Gel
Charged the phone last night before I went to bed and today now at 5:07pm it still has 88 per cent charge! Don’t know what happened the other day, I didn’t use it much.
More than likely had a update after a update its wise to turn the phone off and on and usually use more power for a while after a update until it all settles down .
Reactions: Gel
