Deleted member 2457
Just been playing some Blu-rays but it is not working, any ideas? Master audio and the rest are working. The amp is a Pioneer Vsx-lx70!
professorhat said:Easy gel!
Is the Blu-ray definitely set to the Dolby TrueHD soundtrack? Some older ones defaulted to the Dolby Digital and you had to manually select the TrueHD version.
BenLaw said:With an oppo I'd be using the blu ray player to decode anyway.
gel said:BenLaw said:With an oppo I'd be using the blu ray player to decode anyway.
Why would you do that?
gel said:gel said:BenLaw said:With an oppo I'd be using the blu ray player to decode anyway.
It just reads PCM then.
BenLaw said:gel said:BenLaw said:With an oppo I'd be using the blu ray player to decode anyway.
IF there are any differences in quality of which component decodes then I'd trust the oppo more. If not, you don't lose anything.
professorhat said:gel said:gel said:BenLaw said:With an oppo I'd be using the blu ray player to decode anyway.
That's correct if the Blu-ray player is decoding.
If the Blu-ray is setup correctly (i.e. check Secondary audio isn't enabled as this defaults the main soundtrack as I remember), then sounds like the amp is faulty I'm afraid.
BenLaw said:Yes the AVR will read PCM but you will be getting the proper soundtrack, decoded by the oppo. And turn the volume up!
gel said:BenLaw said:Yes the AVR will read PCM but you will be getting the proper soundtrack, decoded by the oppo. And turn the volume up!
I don't like doing it that way.
daveh75 said:RTFM!
gel said:daveh75 said:RTFM!
What does that mean? I have hooked the Oppo back up but still not working!
CnoEvil said:gel said:daveh75 said:RTFM!
I think he's suggesting that you have a read of the manual.
