Roby said:
So I didn't try the Superniat an this is because when I was looking to upgrade my system the combo Niat cd an Niat xs
are around the same price as the combo M6i an M6cd. So yesterday I didn't really thought about it....
But anyway I think I had a pretty good impression of the Naim sound (although there was one negative point I noticed an that I didn’t mention, that’s there was a strong sss sound present but I doubt this would have been better on the Superniat).
A bout the price well ruffly taken
The combo M6i = 2400€ + M1 ViNL 900€ (witch I need) so that make around 3300€
The combo prx &pre 1850+2950= 4800€ and it already have a phono stage
M6500i is about 4500€ an have no phono stage so that makes it the most expensive solution.
My budget will be between 5500€ at the moment, can also be stretched a bit as I'm not in a hurry (but the amp is the most important because I have a Buyer for my nad around June)
So at first I thought I change the cd player as well. Now I changed my mind an think I keep the CA for the moment an play it true a decent Dac or maybe the clic....
So like I mentioned in a previous post.
Basically I was thinking
Purchase
M6i 2400
M1 ViNL 900€
Concept TT 1100€
clic 1125€
Witch makes a ruff 5200€ with cables included
Let’s say it’s an changeable list, I can play inside the list, let say I don't buy the Clic an do it later or keep my current TT an buy the concept later or just buy a Dac for the cd player.... As I don’t really need a streamer for the moment.
(Speakers will change sooner in that case)
Just think of it as a basic idea
Because if I think the prx&pre combo is really worth it I will have to move some thinks to a later purchase.
The idea is also to change the speakers in 2 years. Until then the 683's will do the job.
As I heard the M6i on the 804 I'm convinced this will be the next needed step. But I was planning to spend around 3 at 4000€ on that top's an I was planning to check out other brands for this because the 804 sounded sweet an super detailed but are around 7000€
An I have to stop somewhere.... (as I have also some construction works starting in my apartment this summer an budget is already calculated but you never know)
An if I take the M6i I can buy new speakers sooner so that the amp comes to his right J
Also I’m thinking if I buy the M6i I can ad the M6pwr afterwards to improve my system (but have to check if it’s worth it of course)
Feel free for anny sugestions or improvement's ;-)
Roby,
First of all, I admire your patience in choosing the right hifi kit. And further impress that you are willing to share your experience in your journey as well.
On the options you mentioned above, I think you have a good grip of the various amps that you have listened to and I have a feeling that you are inclined towards the M6i. And now its just a matter of you asking yourself - 'hhhhmmmm what if I spend another 1500 euro on the pre+prx, will I get a better sound?' The only way to find out is to have a listen to the pre+prx. In my earlier post, I mentioned that I would reserve my words on the pre+prx as I have demo-ed it as well. And you know what I chose in the end.
What I did was to compare M3i to M6i and to Pre+PRX. And what I found that the extra money to spend on M6i over the M3i was well worth it with significant improvement on SQ....but unfortunately (or maybe it was fortunate to wallet
) that I could not justify to myself to spend even more on Pre+PRX as I could not hear much different in SQ compared to M6i.
But as I said, please have a listen first on the pre+prx.
On phono stage, having the M1 ViNYL will offer you more options to match the cartridge on your Concept TT. Are you upgarding the cartridge from MM to MC on your purchase? I would not choose my amp just because the amp has a built in phono stage. If you want to do that, then I suggest you have to listen to the Concept TT played through the bulit in phono stage on M6 Pre+PRX. Basically, if you plan to heavily use your Concept TT, then your demo should include listening to vinyl via the built in phono stage.
Good luck...sorry for the late feedback. I am on one my travels again and have just landed in Paris last night and having a brain freeze due to the -8 celcius temperature
