I am trying to go for a used Power Amp (MultiChannel) and currently considering between the above two
My set up is 5.1 only and in case I upgrade I will go for a 9.2 and hence with respect to the number of channels both these amps mean the same for my requirement.
I will pair it up with Denon AVR till near future (I currently have AVR2310 but am looking at either AVR4311 or Marantz AV 7005 - budget limitations)
I might get the Rotel cheaper but it is also an older model. Has the tech improved? Rotel is THX Ultra certified too but with out the bells and whistles if Marantz does the job much better then it could be the one too.
Also any other amps need to be considered in less than 1000 pound (used) range?
