A andywscott New member Oct 15, 2007 24 0 0 Oct 26, 2010 #1 Hi I'm looking at the possibility of the MT-30 speaker package as I'm limited for space & was wondering if this would be a good choice of amp to run them the Yamaha RX-V1067 any other amp suggestions would be good.
D Deleted member 2457 Guest Oct 26, 2010 #2 I have heard them with the pioneer vsx-lx52 and that sounded really good i also used to own them and had them paired with a pioneer vsx-lx70 and that was good too. Personally i found matching them with a pioneer gave them a really nice sound
B Big Chris New member Apr 3, 2008 400 0 0 Oct 26, 2010 #3 Run mine off a big Onk. You should check out the Onkyo TX-NR808 (which is the current best buy up to £1k.) No complaints here whatsoever.
bigboss Moderator Mar 25, 2009 6,441 1,384 27,570 Oct 26, 2010 #4 Also check out the Yamaha RX-V2067. The 1067 will drive your speakers fine, but if funds allow, the 2067 will offer superior performance.
