Mordaunt Short Premiere Plus 5.1
Hi - does anyone know if these are a good set of speakers for a start up system? I can't seem to find a review anywhere. Would appreciate your thoughts if you have them / tested them before.
Try this...
http://www.mordauntshort.com/assets/documents/whf_july_04_avant5-1.pdf
Thanks - I'll take a look. Stupid question but are the Avant's the same as the Premiere Plus?
No, only the subwoofer is the same as in the Avant package. In all other aspects the 'Avants' are vastly superior and much larger too. The premier plus is one of those smaller style packages as they are known. cheers
I actually own them and am in the process of upgrading them at the moment. They're very good speakers for the price, although the subwoofer is pretty "wooly". I'm keeping a pair of the satellites as my rear surrounds. Possibly a little lacking in bass all round, but only a touch, and I'd still recommend them.
Are you using the sub to power the speakers? (I heard that can be done somewhere) because taht 309 sub is a quality budget sub and in my opininon anything but 'wooly' when powered with a reciever as the avant package.
As for the the premier plus I would say if you can get it cheap then go for it, as you can upgrade bits at a later date.
Oh the 308. Yeh big difference. I agree with you then. Make sure you get the 309 it's awesome for the price.
