Mordaunt-Short Alumni Speakers , help !!?
Hi, has anyone got some Mordaunt-Short Alumni speakers ? if so what are they like ?
im just about to buy some to go with the Onkyo 606 amp , has anyone got any negative comments on the Mordaunt-Short Alumni ??
thanks
I have set of alumni speakers (7:1) and find them great - having said that I am no expert - I did read a couple of `expert` reviews saying the sub is a little on the `light` side if you are a real bass freak.My only serious critism is the instruction manual (1 sheet) which very poor i.e it shows sub standby switch with either on or standby positions but completely forgets to tell you the standby position is a center unmarked and unannotated positon.However the online customer support is very responsive and they make up for litrature.They look better than most but are very heavy(especially centre)if you are wall mounting like me make sure you have decent wall s to fix.
Hope this helps
